The ASIC ACL hardware table utilization has exceeded 90 percent for the above resource. This may cause ACL installation failures for features that leverage ACL hardware.
ACL table usage can be reduced by unconfiguring some ingress/egress ACL filters.
Notice
The utilization of %tableName% hardware table on slot %slot% has exceeded %percent%%%. (Logged at most once per hour.)
| Name | Type |
| tableName | String |
| slot | Slot |
| percent | uInt |
